GMRS What and Where to Buy for RFTW 2025 and Beyond
Some of you may or may not know that in May 2024 the Central Route piloted and tested a new communications system for on-road communications while underway during our Mission from Ontario, CA to Washington, DC. GMRS Radios were used, and a GMRS repeater was also tested. This technology has much further range than CB, and with clearer reception and transmission.
The CB radio service was originally established in 1949 and their usefulness and heyday of the 1970s has been outlived. A new replacement was needed for the unique communication requirements of RFTW. Motorcycle manufacturers have been discontinuing installing or offering CBs, or if they do, they are very expensive. And third-party motorcycle CB radio manufacturers, like J&M have also stopped making and supporting them.
The results of the test in May 2024 was positive and exceeded expectations in most cases. Communications were clear with no relays needed to pass messages and the comms range was significantly extended with no outside interference.
At the July 20, 2024 BoD meeting, the BoD changed the SOP and left it up to each Route Coordinator’s discretion and decision to use CB or the new GMRS Comms for the Run in 2025 for his respective route.
On July 29, 2024 all of the 2025 Route Coordinators (Central, Southern, Midway, and Sandbox) met in a separate RC only meeting. ALL FOUR Route Coordinators are in lockstep, and unanimously decided that GMRS Radio Communications is the way to go and decided that all routes will use GMRS in 2025 as the primary mode of on-road communications for RFTW.
This means that ALL PACK Leadership WILL BE REQUIRED to have and use a GMRS Radio in 2025, i.e. All Platoon Leaders, APL’s, Tail Gunners, Road Guards, Chaplains, Medics, and Chase will need a GMRS Radio. Pack riders and FNGs are also certainly allowed to get a radio and listen.
**Regarding outrider and forward crews and teams such as Fuel, Staging, Ambassadors, and Outreach, it is HIGHLY RECOMMENDED that you start to use and get on the GMRS bandwagon as you will be able to hear the pack miles before they get to your location.
There are numerous off-the-shelf radios available that can be made Bluetooth capable if you have a Bluetooth helmet headset, like a Sena or a Cardo. If you do not use a Bluetooth helmet set-up, there are some wired solutions available, as well.
Option 1: (This option is a HIGH recommendation. Bluetooth.)
The radio is available at the BTECH website, and at Amazon.
Use Coupon Code: RFTW
You will get both the Radio and Wireless PTT button for $152.44.
Add both items to online cart and then apply code.
Deal ONLY Available at the the BTECH Website, not Amazon.
To get “More Range” out of this handheld, it’s all about the antenna quality. Consider a higher quality antenna, or even an external antenna.
https://baofengtech.com/product/nagoya-na-701g/ref/gmrs/?campaign=5.5inchAntenna
https://baofengtech.com/product/nagoya-na-771g/ref/gmrs/?campaign=15inchAntenna
https://baofengtech.com/product/nagoya-ut-72g/ref/gmrs/?campaign=mountedantenna
Midland MXTA26 Antenna – need an adapter, NMO mount and coax with this option. This antenna has the most GAIN.
Option 2: (Also a High Recommendation, but does take skill to install. Bluetooth.)
Vero VGC VR-N7500 High Power 50W/40W Transceiver. This a PERMANENT MOUNT Bluetooth unit. It transmits at up to 40W on UHF (GMRS) frequencies. 4X the power of the above handheld.
Get the Bluetooth button for this radio - Here
This unit requires an EXTERNAL Antenna, like the Midland MXTA26 Antenna. I like this antenna for a permanent install (or a handheld radio with an NMO Mount and Adapter).
An NMO Mount, and Coax are REQUIRED.
Kirk Olson – Central Route RC is running this set-up on his BMW K1600GT. The radio is Bluetoothed directly to a Sena 50S helmet set-up. The included mic shown in picture is not used.
(See a Picture of the set-up here)
** Currently, the VR-N7500 DOES NOT Bluetooth Connect to a Harley Branded Sena. It does connect to a regular, non-Harley Branded Sena. It must be something to do with the HD Firmware.
** There is a rumor that BTECH is coming out with their version of this radio in the very near future.
Option 3: (Non-Bluetooth Radios, and not ideal)
Any GMRS Radio like these:
TID Radio H8 GMRS Radio:
https://amzn.to/47klXzu
Amazon.com or here
Amazon.com **Recommended (Value Pack)
Video on the TID Radio H8: https://youtu.be/8HXSlHT84yQ
Baofeng UV-5RTP: Amazon.com
*These radios ARE NOT Bluetooth capable to a headset from the manufacturer, so would best be used with a wired set-up, and an earpiece or earbud.
A company called Rugged Radios are the BEST wired harnesses for those that do not have or want a Bluetooth helmet set-up, and they also offer Bluetooth for any radio, and are built for motorcycling.
Wired & External Bluetooth harnesses options from Rugged Radios. These harnesses work with almost any GMRS.
Option 4:
If you are an Amateur Radio Operator (HAM), you may be interested in the Anytone ATD878UVII Plus. This is a HAM radio, and can be unlocked for GMRS use, and has Bluetooth built-in that will pair to a Bluetooth helmet set-up. This option does require good computer skills to program the radio.
Option 5:
Any Four-wheel vehicle can use a GMRS handheld or any Mobile Car/Truck Mounted GMRS radio.
Manufacturers of these are: Midland, Wouxun, to name a few.
These also require:
An EXTERNAL Antenna, like the Midland MXTA26 Antenna
Licensing:
Lastly, listening to a GMRS radio does not require a license from the FCC.
Transmitting on a GMRS frequency currently, technically does require a license from the FCC and is easy to get, and is $35 for 10-years.
One license can be used per family.
Video on How-to get a GMRS license:
Click here to establish your FCC FRN Number: FCC Registration - Login
Click here for the FCC Universal Licensing System: https://www.fcc.gov/wireless/universal-licensing-system
Thank you.
See you in May 2025
Kirk Olson - Central Route Coordinator
Eric Fort - Midway Route Coordinator
Ken Ley - Southern Route Coordinator
William Brehler - Sandbox Route Coordinator
Kirk, thank for the advice. We’ve updated both bikes with the MXTA26 antennas, NMO mounts and coax. See pictures attached. We are running Cardo headsets which allows for four connections, but have to figure out which position to put the radios in so that it’s not being kicked out. My bike MUST be connected to the headset. I have two cell phones android and apple and radio. My have to give up the android.
Hello,
Any way to show close up pics on how your antenna is is connected to your bike? More over the mount and that set up.
Sure, I’m not at the bike now but I will respond to your post tomorrow with some close ups
Attached are some close ups of how I mounted the MXTA26 antenna and coax.
I already had the flag mounts from Goldstrike.
Basically the flat piece of metal came with my cable. I did some grinding used the same hole and screw that came with the flag mount and drilled/expanded the hole in the flat piece just large enough to run the coax from the bottom then screwed the antenna on top. Then hid the 13’ coax under the seat.
We purchased a couple of holders and other items from Amazon to make the install complete.
1000010319
1000010321
1000010322
thank you kindly for doing so. I wanted to get an idea on setup you have in relation to one i am looking at doing. Looking for a similar mounting plate (for say) you used to attach to bike to hold the antenna. Appreciate these close up pics.
Mounted on the F6B
1000010329
1000010331
1000010333
1000010327
1000010331
1000010333
@jhudd17 This is really a great install. Thank you for putting this out there and posting your success.
Brother it was your guidance and advice that put me on the right track. Thank you!
Hey Pretty Boy!
Thanks for the post. Since all GMRS radios are not created equal especially in frequency availabilities, could you specify precisely what frequencies will be used, just so no one is sad-faced in May 25? (462.7250?)
Thanks.
Central Route will continue to use GMRS Channel 22, which is: 462.7250, with the CTCCS Code: 103.5 applied on the Tx and Rx.
To make things simple, we may advise ALL RFTW, including Southern, Midway, and Sandbox to also use those settings to make things simple, much like all RFTW used CB Channel 2.
Central Route does also have a repeater that we may deploy. We MIGHT use RPT Channel 22 (Which is a different channel). Also with CTCCS Code 103.5 on Rx and Tx.
Thanks, Kirk. That does makes things pretty simple.
Gonna be GREAT.
BAOFENG RFTW DISCOUNT
We have negotiated a group discount rate with BTECH/Baofeng. Purchase both a GMRS-PRO Radio and a BS-PTT Button and use coupon code “RFTW” at checkout and you will receive 17% off your purchase.
Do you have your MXTA26 Antenna grounded? Also if you have information on your F68 mount. Trying a similar set up but like how yours is lower profile, but i am getting a high SWR
Yes, it is grounded via the motorcycle rack, bolted to the frame.
Perfect got it fixed and at 1.02 reading on GMRS SWR meter.
